Well I pulled the TCM and checked it's connector with the key on engine off and it has keep alive power as well as regular power. I found the way to test for codes without a tester and ran the test with a trouble light and got the following:
- 23 TPS (I didn't move the FIPL lever during test)
- 26 TOT (truck was not warmed up)
- 91 Trans sol 1 failure
- 92 trans sol 2 failure
- 93 TCC failure
- 94 TCC failure
This all leads me to suspect the connector to the solenoid pack on the pass. side of the truck. When I first got the truck I had issues and removed and cleaned that connector. It turned out to be a ground connector was not hooked up near the battery. I pulled the connector tonight and noticed minor corrosion so I'll get some cleaner tomorrow and see if that helps. Can buy another connector anywhere? What about the one on the trans itself? Is there a separate harness from the TCM to the trans I could/should replace? Could this be a ground issue once again? I rechecked the connector that originally gave me trouble and it's tight and clean.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
