Originally Posted by butchcassidy1
If you are looking for more heat, then yes, it will give you that, BUT, that is it.
If you are looking for better MPG - forget it, you can get better MPG by keeping the truck light, no lifts, nor oversize tires, speed under 60, and treat the go pedal like an eggshell.
If your truck gets checked for emissions with this tstat, do not be surprised if you are not passed on the emissions test.
Hopes this helps,
Butch Cassidy1
O
Why would that change our emissions? our worst emissions are at idle after startup with a nice cool engine.....
( I am just curious - have always run the OEM Ford thermostat myself)
1999.5 F250 Crew 4" Magnaflo Turbo back exhaust, DIY intake, AIH Delete, HPX Line, zoodad mod, Wicked Wheel, Gauges (Tranny, Boost, EGT) DP-Tuner  ITP "In-Tank" mod and prepump filter, RiffRaff FRX Regulated return, foil delete and lighted cup holder...that's right - lighted cup holder.
