Diesel Forum - TheDieselStop.com - View Single Post - What metals are ok to use with wvo?
Old 10-13-2009, 12:10 PM   #1 (permalink)
ClassicFordGuy
Thinking about how to set up my truck for wvo and am not sure some of the materials I want to use are ok.
was going to make my tank out of steel, probably 60 gal in place of my 20 gal rear tank.
Fuel pickup out of either aluminum or steel with a copper coil through the middle using brass fittings. (coolant circulates inside the steel tube while oil is sucked through the copper tube).
So any idea if any of these are bad for bio, coolant, or diesel?
Steel
Copper
Aluminum
brass
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline   Reply With Quote
