Diesel Forum - TheDieselStop.com - View Single Post - Lack of towing power
Old 10-13-2009, 01:19 PM   #59 (permalink)
djousma
Originally Posted by teamroper60 View Post
Low voltage to the FICM would likely through a P0611 code and/or low circuit codes for the injectors.
>snip
In my case, 12V to the FICM was ok. there was no CEL. The problem was that the FICM was supposed to put out a nominial 45V and it was only putting out 29. Since the replacement, my towing power has returned. I dont know if a code was thrown for that or not. When I brought my truck in, they were expecting to do a EGR service, and possibly Turbo. when I got it back, they had replaced the FICM. So, unless FICM diagnostics are a routine thing they always do, I expect that a code was thrown to lead the tech there.
2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
djousma is offline   Reply With Quote
