Diesel Forum - TheDieselStop.com - View Single Post - IDM Code
Thread: IDM Code
Old 10-13-2009, 01:45 PM   #26 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by TXF-250 View Post
Hello again,
I just got off the phone with Auto Computer Exchange out of FL and was discussing my problems with them and inquiring about a new IDM. They felt that based on what I was telling them, this seemed to be a PCM issue and not IDM. They said the IDM would cause you to lose and entire bank of the engine and not just 1 injector.
How can i test the pcm or wiring harness to it?
Does this seem right?
I'm not sure I'd agree with them, but they do repair them.
Where are you located? If in Texas (guessing from your username), there are probably a million 7.3L's running around there. I know there are lots of TDS members, and one of them may be willing to help you out by loaning you an IDM. try the Power Stroke Help Network - 1994-1997 Power Stroke FAQ, and see what you come up with. I'd hate to see you buy an expensive IDM and/or PCM and still have the same problem.
I admire your persistence in checking continuity between the IDM and heads. That's something I'm sure I wouldn't like to tackle.
Hard or no-start? Check Here
