Diesel Forum - TheDieselStop.com - View Single Post - exhaust brake???
Old 10-13-2009, 09:25 PM   #12 (permalink)
SmokeyWren
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by xcr8oo151 View Post
has there been a update to the diy install for the auto? if you were to just close the butteryfly and not used the brake to keep the conv.locked would it be of much good to set it up on a on of switch.that way when u come to a stop and forget to turn it off,the engine won't try to stall out and u will remember when u don't go very fast that it is still closed.am i thinking about this right or am i missing something.
I suspect you're right. Lots of folks use an electronic exhaust brake without a torque converter controller. When comin' down the mountain, if you can resist touching the brakes (which unlocks the torque converter with most tunes) and keep the RPM up over 2,000, then the closed EBPV does a decent job of retarding. But touch the brakes and the retarding action almost disappears when the torque converter unlocks and begins slipping.
SmokeyWren is offline   Reply With Quote
