Diesel Forum - TheDieselStop.com - View Single Post - Can a E-350 6.0 work in a SD?
Old 10-14-2009, 03:20 AM   #2 (permalink)
kodaman
Banned
Originally Posted by fordnut350 View Post
What are the differences between the 6.0 Powerstroke in Econoline vans and the Superduty trucks? Is it worth the headache to use a Econoline motor? I have a chance to get a motor out of an 05 Econoline and was hoping to help out a buddy who needs a motor in his 04 F-250. I figured it was a bolt in, but thought I should check. Do they use they same computer? Also what are the differences in the auto trannys? Can just the tailshaft be swapped? His truck is a 4X4. The Econoline only had 85k when rolled. What is a fair price for the motor and tranny if they can be put into the F-250?
GrampyJim tells me that the motors are essentially the same...The Econoline is rated at less HP because the E-box has a smaller charge air cooler.... The FICM will work but should be reflashed.... PCM? dunno.... You'll prolly be better off with the truck PCM and wiring harness... ICP and EBP sensor MAY need some wiring changes...
Rolled... this gives him cause for concern... the motor should stall before oil pressure is a concern... but did it hydraulic?
Transmission... he figures that the output shaft may have to be transferred.... You will have to unstack the entire transmission and restack it... some special tools required....
FWIW... one of the moderators has banned GJ for life meaning I have to post stuff for him.
kodaman is offline   Reply With Quote
