going good
well its going good been working on it in spare time for 2 weeks ihave something else i can drive ,im not sure how many pics i can post one here but its coming together
well , one problem i dont have a welder so i got to depend on others for making me brackets (and you no that blows) but i should only need 4 brackets made no biggie i went with silicone pipes because there insulated there a little bigger than your std 3 in pipe . 3 inch pipe is the size to use for everything .
once you remove air cleaner assmblemy and the reorganize ford wiring harness , it seems like like wiring neetness was no concern atleast on mine they put it in the plastic housing all twisted up notted up etc so you have to disconect all the leads and untangle then reconnect then you the slack you need to get it out of way this is good .
heres is some shots one with aluminum pipe from a older f- just for the *** of it .
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
2001 E350 4.10 all stock cargo 140k
