Diesel Forum - TheDieselStop.com - View Single Post - Can a E-350 6.0 work in a SD?
Old 10-14-2009, 10:19 AM   #3 (permalink)
kman780
If you want to use just the motor you should be OK, you should use the truck harness, computer, air intake/filter, etc... Also, depending on the 04 your buddy has the motor may look a little different and the computer will act different. The later model (fixed) 04 motors are different slightly and some o the way they determine boost, etc is different.
I cannot comment on the trans but I am sure you can find a way to make it work if you really wanted to. If you can find an new style (late 04+ with a complete truck harness, intake, etc) that would make it a lot easier.
kman780 is offline   Reply With Quote
