Diesel Forum - TheDieselStop.com - View Single Post - Tuner, Exhaust, Air Intake? Rate them in priority.
Old 10-14-2009, 11:00 PM   #2 (permalink)
Stymie
Stymie's Avatar
if you get a tuner, and run larger than a 210 tune, the intake is required. it will suck the filter minder in and tell you the filter is plugged. the exhaust isnt required, but helps alot. with a muffler, the in cab noise is kept very well in check.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline   Reply With Quote
