Originally Posted by klhansen
Correct.
What does the buzz test sound like when you run it? All injectors should buzz first, then each one individually, in numerical order. They should all sound pretty much the same. If the #7 sounds weak, or the buzz sounds like it's coming from the IDM when it's #7's turn, then that injector solenoid is sure suspect.
The buzz test actually applies the high voltage to the solenoids so is a different test than just measuring the resistance of the solenoids.
Yes, when the buzz test is run, all of them at the same time sounds the same (maybe a LITTLE variance). Now, when each one is buzzed, they all sound pretty much the same (again maybe a tad of variance)...but no. 7 ( i think it is since thats the code that comes up) is noticeably different.
Is there anywhere that sells just the solenoid?
Jourdan
2011 F250 King Ranch FX4, 6.7L with all the options
SOLD: 2002 F250 Lariat 4x4, 7.3L
DIY Intake, Zoodad, 4 inch exhaust turbo to tip, DP Tuner F5 (no start, stock, high idle, 60hp tow, 80hp econo, 120 hp race), Isspro Gauges: egt, boost, tranny (thank you girlfriend!:hail), Dieselsite Coolant Filter, AIH Delete, HPX Line, in-tank & pre-pump mods, FPR shimmed to 70 psi, Hawk Brake Pads and Powerslot Rotors, Dieselsite WW, Rhino Bedliner, 285/75 Goodyear Wrangler Silent Armors, Trailer Tow Mirrors, Bilstein Shocks, 203* T-Stat, Dieselsite Billet T-Stat Housing, Door Seal Mod, Fumoto Oil Drain Valve, Passport 9500i hardwired in w/ smartcord, A toolbox full of goodies and a few other things here and there:sly
