Diesel Forum - TheDieselStop.com - View Single Post - Follow-up on Coil Spring issue - Thanks!
Old 10-15-2009, 06:31 PM   #3 (permalink)
Bruce1954
Jason
Again if springs are available for the 2000 to 2004 F-250/350 there should be some that would work, you may get a slight lift out of these also.
There may have been a few on other excursion sites that did this to 2WD Xs
most of us here have the PSDs and I think a higher % of the PSDs tend to be 4X4s so there may be help other sites as well.
Sounds like you have it for now, good luck
Bruce
Originally Posted by Jason Air Force View Post
Hello,
Thanks for all of your help - some info for you.
2wd Excursion coil springs are indeed an obsolete part from Ford. I contacted Ford directly as well as 5 dealerships throughout the continental US and there are none in stock anywhere.
Those two websites - powerstrokeshop and ford discounted parts are both Ford dealerships using a different name to sell online and didn't have any as well.
I located a set (atleast I am hoping) at a junkyard in South Carolina and they are being shipped to New Jersey as we speak.
Still not sure what broke the thing but we love the X and will never get rid of it. My last resort and it is still not out becuase I am still not driving it is a Fabtech 4in lift. So if it comes to that I guess I will have to get some bigger tires too.
Thanks again for all of your help - I was able to check alot of different places I would not have known about with the forum.
Jason
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline   Reply With Quote
