Sorry, I don't get here very often anymore... The V3 is the more expensive system. Frybrid still uses 3 way switching valves on the OBS trucks because they use an engine-driven fuel pump for diesel AND the fuel system on those trucks is not 'deadheaded'. The electric fuel pump required for the later-model trucks costs alot more than the 3 way valve systems. DFA actually replaces the OE mechanical fuel pump with a 2nd electric pump on OBS trucks - so their OBS system is even MORE than 'standard' V3 system.
Frybrid uses an exclusive 'heated fuel pick-up' which is basically a module that drops into the top of the fuel tank. It avoids 'heating the whole tank' and instead focuses almost all of the heat right around the fuel pick-up. There is nothing else available that even comes close to how fast and HOT the oil comes out of this thing! I think Frybrid's 'kit' price includes one of these pick-ups, ordered to your specifications (iow, ya tell them how deep your tank is) - but, the actual tank would be extra. So, yes, you may save some $$ having someone local build your tank. Where you are, find someone who builds tuna towers or custom boat fuel tanks. Around here, you can usually get about a 40gal custom tank built for $500 or so.
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
