Originally Posted by Pol386
Any help is appreciated, we are looking at a 2010 Cardinal 5th wheel model 3515RT. It weighs 12855 with a pin weight of 2135. We have a 2008 F-350 SRW 6.4 as a tow vehicle. My question is, can I safely tow this amount of trailer with the vehicle I have. Thanks RWH
that's a walk in the park for that truck. IMHO
I'd pull that load all day long even through mountains if I had to, w/ my y2k F250
I'm sure more will chime in.
 y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
