Diesel Forum - TheDieselStop.com - View Single Post - Towing Question?
Old 10-15-2009, 09:06 PM   #4 (permalink)
rskeans
Originally Posted by Pol386 View Post
Any help is appreciated, we are looking at a 2010 Cardinal 5th wheel model 3515RT. It weighs 12855 with a pin weight of 2135. We have a 2008 F-350 SRW 6.4 as a tow vehicle. My question is, can I safely tow this amount of trailer with the vehicle I have. Thanks RWH
The 3515RT GVWR weight is 16,135 lbs. The weight you provided is the dry weight. You need to use the GVWR weight. I haven't researched all of the towing and weight specs, but I believe that you are significantly over the maximum weights for your truck. You didn't provide the axle ratio, or other things that affect your maximum towing capability.
All the above being said, it is not uncommon for such weight to be pulled behind your 350. Your brake controller will control the trailer braking. IMHO that is the most critical thing. You could be subject to some liability if you should be in an accident.
'08 F350 Lariat CC 6.4 DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
rskeans is offline   Reply With Quote
