Diesel Forum - TheDieselStop.com - View Single Post - Taking The Cab Off For Head Studs
Old 10-15-2009, 09:44 PM   #8 (permalink)
Ranger_713
Ranger_713's Avatar
You can pull the engine out the front easier. Pull the radiator and core support, drop the oil pan and she'll slip right out. To check for studs, look at the outside edge of the heads towards the top, under the valve cover lip. Do you see a large bolt head, or a large nut on a stud? There's your answer.
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
Ranger_713 is offline   Reply With Quote
