In a nutshell, we use a seperate, redundant fuel system for VO. This includes a VO tank with heated fuel pick-up, fuel pump, pressure regulator and a filter. This secondary fuel system is heated using engine coolant.
There's alot of ways to rig up a conversion. Some people even appear to get lucky doing just that - but I have personally met (and seen the carnage!) quite a few people who it did not work out so good for. Trust me, if you 'do it right' - you WILL get your money back if ya drive much. Doing anything less will likely leave you on the side of the road when it is least conveinient and your spouse, in-laws, mechanic, etc. will also insist you were in fact a dumbie!
Like they said, be sure to read about Dino Fuel Alternatives V3 system. It truly is the Cadillac of VO conversions and worth every penny. I used the Frybrid V3 system in wifes Excursion - Frybrid gets V3 module from DFA and includes some of their exclusive VO tricks with their system.
Oh yeah, my truck has over 110k miles on VO and Excursion is over 40k miles now...
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
Reason: RULES VIOLATION
