Diesel Forum - TheDieselStop.com - View Single Post - upgrade intercooler ? ? ?
Old 10-16-2009, 09:18 PM   #1 (permalink)
ronchyhiker
I have a 2000 p/s and was about to do the 6.0 intercooler in 7.3 mod. My question,now,after doing some measuring,is it really going to help. If my figures are correct,there is 1065 cu.in.in the 7.3 and 1216 cu.in. in the 6.0 intercooler. Is this small difference of 152 cu.in. going to make any difference in the cooling of the air from the turbo?
I was going to do this mod based on replies on other forums as an inexpensive way of additional cooling. Really confused, now.
Thanks for your replies.
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline   Reply With Quote
