Originally Posted by Btravelen
AND, likely the recent flash.....
Actually the MOST recent flash is easier on the FICM than the one it replaced. As I understand it, the one it replaced was from International and it was hard on FICM's - especially when system voltages dropped and it had to work harder.
Mark
