Diesel Forum - TheDieselStop.com - View Single Post - What Air Intake should I get...??
Old 10-17-2009, 07:59 AM   #4 (permalink)
69ttop502
Originally Posted by dirtboy25 View Post
yes,... you will see typical gains of 5 to 15hp and more turbo noise depending on the system that u choose. stock is restrictive and upgrading will improve mileage, turbo response, egt's, and torque.
if u are going to upgrade try to stick with a sealed intake system such as S&B. they work very well with keeping intake temps to a minimum, they flow well and they are iso certified.
That may be true on the 7.3 but the consensus here seems to be that with the system on the 6.0, stock is best. You won't see any significant gain until you are over 500 horsepower. If you still have warranty as well, keep it stock.
2007 F350 Lariat CC SWB 4X4 SRW Torque Shift. True Blue with Medium Flint. 20 inch wheels, FX4, Moonroof, sliding rear window, Tow Command, dual alt's.
69ttop502 is offline   Reply With Quote
