Sal,
That may be just the TC slipping and causing the code. I would find out what code it is throwing before doing anything. Mine started doing the same thing a couple months ago. It was the TC slippage code. I just left it in limp mode after re-setting it a couple times and then it just turned off on its own. I guess after so many cycles without the same trigger it resets itself. I'm sure it will be back on as soon as I get on it. But, since I use it to tow a 5th wheel I bit the bullet and had a BTS trans built. I'm having it put in at Beans on Monday and can't wait. Good luck.
1997 F350 Auto, 111,000 Miles, Crew Cab, DRW, Fire Engine Red, AFE Cold Air Intake, VDO 3 Gauge Pillar Mount, Super Chips Max Micro Tuner, 3" DP into 4" MBRP Exhaust, Bean's Fuel System.
