Diesel Forum - TheDieselStop.com - View Single Post - charging issue
Thread: charging issue
Old 10-18-2009, 08:48 AM   #4 (permalink)
StrokerSmoker7.3
StrokerSmoker7.3's Avatar
If the alternator voltage output is fluctuating with the RPMs sounds like bad diodes in the alternator. I just replaced mine this week because of the same thing. One easy way to tell is, if you sit at a red light or stop sign at night with your headlights on, do they dim when you come to a stop and then get brighter when you give it throttle? If so, the the alternator has one or more bad diodes.
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline   Reply With Quote
