Diesel Forum - TheDieselStop.com - View Single Post - charging issue
Thread: charging issue
Old 10-18-2009, 10:20 AM   #5 (permalink)
Cjhstang
Cjhstang's Avatar
Originally Posted by StrokerSmoker7.3 View Post
If the alternator voltage output is fluctuating with the RPMs sounds like bad diodes in the alternator. I just replaced mine this week because of the same thing. One easy way to tell is, if you sit at a red light or stop sign at night with your headlights on, do they dim when you come to a stop and then get brighter when you give it throttle? If so, the the alternator has one or more bad diodes.
i know it sounds weird but i figured that was normal.. its done that since i bought the truck 4 years ago.
is there a way to test the alternator while its in the truck wo taking it to napa or the like?
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline   Reply With Quote
