Diesel Forum - TheDieselStop.com - View Single Post - Towing Question?
Old 10-18-2009, 10:05 PM   #13 (permalink)
Bill1013
Bill1013's Avatar
One key thing most folks do not think about with heavy trailers is the trailer brakes.
Only thing making the brakes work is the trailer plug connection and a wire going back to the electric brakes.
If you have a broken wire, bad connection in the plug, or the plug is loose or falls out of the receptical on the truck, then you have no brakes.
On most ALL RV's they do a lousy job on the brake wiring at the wheels. Get some split plastic conduit to protect the wiring, wire tie it up behind the axles as much as possible. Road debre can possible break the wiring especially on gravel roads. Ask me how I know.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline   Reply With Quote
