Listen to Jason,
he is correct on you get what you pay for. I rushed into it and luckily didnt have any major issues before I nearly rebuilt an entire system from my failed GFS kit for my excursion. The DFA kit is by far the best out there. You can build a kit that is similar but it would be hard to do if you want something that is totally automated. CHeck out FRYBRID SVO/WVO FORUM an open and public discussion of Vegetable Oil as a fuel lots of good info on there. By your user name it sound like you have an 01 so you are good to go. A properly fed 7.3 kicks ass on WVO. I am 40k in in 2 years and loving it. Be aware this can become obsessive!
