Diesel Forum - TheDieselStop.com - View Single Post - 6.2L Detroit Diesel info please
Old 10-19-2009, 04:53 AM   #4 (permalink)
Huff
My Photos: (33)
That is a solid little IDI diesel, the 6.5 is it's big brother. The only trouble that I am aware of, is if they spend alot of time ideling the timming chain takes a beating and can get to slapping around in there. The noise will dissapear just above idle. If the noise is pressent you will need a new chain pronto. Banks has turbo kits for them. Also head gaskets can be an issue in high milers (around 250k) if the cooling system has not been properly maintained with the supplimental coolant system additive.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff is offline   Reply With Quote
