10-19-2009, 10:40 AM
#19 (permalink)
Originally Posted by eriol
I had a problem with the rear brakes, too:
On the driver's side, the slides were seized up and I had an uneven wear on the pads: The inner one was gone, the outer one nearly new. On the passenger side, on pad was worn parallel, while the second one was wedged by 1/8 of an inch!.
Finally, the caliper on the driver's side failed.
I replaced everything: calipers, rotors, pads.
But: I have AFTER the replacement dragging brakes, I can notice it in the fuel consumption. When I replaced the rear brakes, I also flushed the brake system and filled is with new fluid. The front brakes got replaced about 6000 km ago.
Any ideas?
Thank you
yes when the rear brakes drag you will notice the truck working harder with out of sight egt's. Along with using a lot more fuel then normal.
