Diesel Forum - TheDieselStop.com - View Single Post - Cruise Control Recall
Old 10-19-2009, 05:15 PM   #11 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by tfenny View Post
I think they install an inline fuse in the circuit that is constantly powered up. I just learned of this today. I was told it could burn just sitting there, taking the garage, etc. with it? Here is a link- Ford Recalls 4.5 Million Vehicles Due to Faulty Cruise Control Switch - Associated Content - associatedcontent.com
The circuit isn't constantly powered up on the Diesels, just on the gassers, so the hazard is lessened. But a fire starting underhood while underway wouldn't be good either.
I recall a TDS member had just that happen to him, so if I was affected, then I'd be taking it in.
The fix for the gassers was a 5 amp inline fuse if the switch wasn't leaking, and the fused harness and a new switch if it was leaking , IIRC.
I guess Ford got nervous about fires in the Diesels as well. At least they're being proactive on it.
Hard or no-start? Check Here
