Diesel Forum - TheDieselStop.com - View Single Post - Oil causing slow start?
Old 10-19-2009, 10:43 PM   #5 (permalink)
Patrick Feeley
Patrick Feeley's Avatar
My Photos: (19)
The PCM doesn't get a signal from the switch on the HPOP reservoir (it's only for the "idiot" gauge). It does look for a minimum HP oil pressure from the ICP though. Possibly the HPOP Oil reservoir is draining down and has to refill. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline   Reply With Quote
