Originally Posted by woodnthings8
Mine has a male three prong plug for the block heater. Is that what you broke, or the connector on the filter base for the block heater? If you just ripped the cord out any 15 amp three prong plug will work. Or you can get a new harness HERE. Also look at the plug adapter that you can install to eliminate the hanging cord deal. Marinco Block Heater Plug Mod
Cool I just ordered 2 of them, 1 for the block heater and 1 for the battery tender. Work is slow this month but this is a mod I can afford!
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
