Diesel Forum - TheDieselStop.com - View Single Post - Engine block heater VS Edge Platinum
Old 10-20-2009, 01:21 PM   #4 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
The heater runs straight off your AC power, it has no connection to the 12V system or the trucks computers.
Something else made the change, not the block heater.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
