Tire size
I went wih the 4" lift and 35 x 12.5 x 18 for tires. I have seen 3 to 4 MPG loss and a little less on take off. I mainly ket it to a 4" lift because I have an Artic Fox camper with slide and the 4" lift means I have to lift it all that much higher. The tires do ride a lot better with the load. You may also want to consider front wheel bearing wear and ball joint ware with the larger tires. I just replaced mine after 136,000 miles. Bigger tires do mean more wear, but also gives you a reason to go with the Dynatrac system. With the 6" lift you can also change the front and rear over to a coil spring/link system. Just depends on how much free $$$ you have laying around. Also 37" tires cost more than 35" tires. Well that is my .02$
DACriss
'99 F250 SD,XLT,PSD,4X4,6spd,3:73,LB, SRW, Steel Horse billet grille, Catch all floor mats,VDO vision boost-EGT-OST dash pod,Mongoose CB, Luk flywheel, Carolina P-plate and Kevlar disc, Built 10/98, received mid Dec., Edge 4.5 lift, Adj. Pan-Rod, Bilstein Shocks,35-12.5x18 Toyo m/T on MKW MK19 10x18 wheels, AFE stage-2 intake,KCM S.S. High Pressure Crossover Kit, '03 TT mirror convertion, '03 AM/FM 6-disk radio, billet thermostat housing w/203* stat, Coolant filter, Evans coolant, Heater/A-C mod., SSBC V8 brake calipers, slotted rotors, custom dual steering stabilizer w/Fox Shocks, Blue Torch front diff cover
