Diesel Forum - TheDieselStop.com - View Single Post - 03 Excursion with Fluid Leak
Old 10-20-2009, 04:38 PM   #3 (permalink)
boomboom
boomboom's Avatar
Also check your coolant recovery bottle CAP for leakage. Could be system over presurizing do to EGR cooler related problems Leak on drivers or passangers side. PS fluid should be redish and coolant does feel oily
boomboom is offline   Reply With Quote
