QUOTE " The batteries were just replaced with new Motorcraft OE batteries. The truck turns over no problem....just doesn't fire, unless I leave it plugged in overnight. "
Is your oil topped of to max.. and also are you running motorcraft oil.. the reason i ask is because the injectors run off the oil pressure. and if the oil is too thin or not enough in the engine then there won't be enough to kick in those injectors .. let me know what you find. thanks hope this helps.. James
2006 Ford F-250 King Ranch, Crew Cab, FX4, 6.0 powerstroke diesel, 20" wheels, 35" Kumho a/t, Bully Dog 150hp extreme. Do It Like It's Your Last Time !
