Originally Posted by MikeL46
The heater runs straight off your AC power, it has no connection to the 12V system or the trucks computers.
Something else made the change, not the block heater.
Mike
Originally Posted by rock_doctor
It is possible. Contact the programmer manufacturer and tell them what is going on. Their hardware should be somewhat tolerant to stray RF. You can try to add a capacitor into the wiring for the programmer. The wire for the block heater runs side by side with the battery cables coming from the starter. It is possible the block heater cord is inducing a stray AC signal into the 12v DC system and it is confusing the programmer. Putting a capacitor in the programmer wiring would filter it out or you could move one of the cables (battery or block heater).
I am under the same conclusion as you Mike. Rock Doc what you are saying seems feasible but I would like to think that Edge has built in safeties that would eliminate stray RF signals. It would seem juvenile to think otherwise. I'll see if the problems continues tomorrow and go from there. Maybe I'll end up ditching the system all together and keep it stock. We'll see....
07 F250 Lariat, 6.0L, 8" Fabtech lift, 38" Toyo M/T's, fender flares, Edge Platium, Magnaflow exhaust, K&N Aircharger, Pioneer Nav/DVD, JL Amp w/ stealth box console, rhino lined, Recon light bar, Recon aux lights, Aries SS bull bar, Viper SST alarm/remote start, Amp Research step bars, K40 Radar
