Diesel Forum - TheDieselStop.com - View Single Post - Cold start issues, please help.
Old 10-21-2009, 11:35 AM   #26 (permalink)
teamroper60
teamroper60's Avatar
Originally Posted by LocoMike View Post
i am confused though, cold oil should be thicker and my AutoEginuty says I have 600+ PSI at Idle on start-up.
In theory, thicker should be higher pressure.... BUT, I will take any ideas.
The only problem with your theory is, the PCM is calling for a certain amount of ICP at idle. Everything above that ICP is bled off by the IPR. So your oil could be as thick as crude and you would still only get 600psi.....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline   Reply With Quote
