Diesel Forum - TheDieselStop.com - View Single Post - Cold start issues, please help.
Old 10-21-2009, 01:45 PM   #27 (permalink)
King Rancher
King Rancher's Avatar
Send a message via Yahoo to King Rancher
Originally Posted by teamroper60 View Post
The only problem with your theory is, the PCM is calling for a certain amount of ICP at idle. Everything above that ICP is bled off by the IPR. So your oil could be as thick as crude and you would still only get 600psi.....
And that is exactly what i explained .. is if you have 600psi of thinned out oil .. compared to the "same" 600 PSI of thicker oil .. the 600 psi pushing the thicker oil gives you more oil moving through your system.
2006 Ford F-250 King Ranch, Crew Cab, FX4, 6.0 powerstroke diesel, 20" wheels, 35" Kumho a/t, Bully Dog 150hp extreme. Do It Like It's Your Last Time !
King Rancher is offline   Reply With Quote
