Diesel Forum - TheDieselStop.com - View Single Post - How to prepare a truck to operate in freezing conditions
Old 10-22-2009, 12:14 AM   #5 (permalink)
ndmtnsledder
I live in ND it regularly gets to -40 plus windshield here I don't think it gets that cold in Detroit regularly though. There are some charts around as to at what temps you need different blends or additives but I've never seen a good one. I usually will start adding a antigelling additive around 15degrees(I use Howes or Diesel 911). When it starts getting down around 0 i'll start going to a 25% #1 blend by the time it gets to -40 I'll run 50% plus blend of #1. Keep it parked out of the wind and better yet if possible keep it inside at night. The new systems do a good job of keeping the fuel warm once its running. The biggest problem I know of is on a cold day run it down to a 1/4 or 1/8 tank then fill with fresh cold fuel out of underground storage and watch it gel. He's also going to want the winter front to help the engine warm up.
ndmtnsledder is offline   Reply With Quote
