Diesel Forum - TheDieselStop.com - View Single Post - What size trailer?
Old 10-22-2009, 05:44 AM   #6 (permalink)
Flywheel
Flywheel's Avatar
My Photos: (6)
I have the BigTex 14GN 20+5 and load a smaller tractor - but up to 10k lbs of hay - 200 square bales or 10 rbs.
I think you will be happy with this trailer - but may want better tires on the truck and trailer. I have 285E rated tires on the truck and 235 E rated BFG Commercials on the trailer, and that made a difference.
The only weak area with a lighter weight trailer is the twist in it - so consider a torque tube. The larger trailers will do it as well, but they are much more robust.
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline   Reply With Quote
