Diesel Forum - TheDieselStop.com - View Single Post - HPOP issues!?
Thread: HPOP issues!?
Old 10-22-2009, 08:41 PM   #3 (permalink)
BTBBT
My Photos: (19)
It sort of sounds like the hpop died but I would think that would trigger a code for low hpop pressure. Do you have a way to check or monitor the HP oil while cranking? that would rule out if your hpop is still working or not.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
