Diesel Forum - TheDieselStop.com - View Single Post - intercooler install on way
Old 10-22-2009, 09:09 PM   #16 (permalink)
VISIONQUEST
VISIONQUEST's Avatar
update
RPM intake im using is http://cfmplus.com/ works fine goes right on i got a scratched up one from them they gave me a little dicount now it will fit 01. i know that older models have a 2.5 it wont fit you would have to get the intake of a truck or just change your intake ports to bigger ones . and yeah your right intake got to be pipe + connector vacuum sucks silicone closed .
dansk there is a little room when yyou get ridd of BS in there
arz, im using a W/A kinda large its going to go were air box was same hieight and width a little deeper , as far as A/A intercooler goes it can be done you would have to move battery to frame and cut some holes on front and measure for size . dont no but you might need alot of patients lol.
currently im kinda stumped been ^%&^*& with this for days trying to just have a complete intake circle for testing purposes but the piping will not stay together , now i know what they meen by pipes blowing off i have a peak around 38 lbs i finaly took it off and laid it on ground and pumped air into it it swells up like a K2 football , when it swells up there is not enough room in the when installed in motor bay, so im going to try to get some pipe mandrel bent
i only need a couple peicies here is some picks with no air and 30 lbs in the pipes any more pressure it would have blew apart . im in kinda deep in this and ima gettting alittle pissed they fail to mention silicone piping realy isnt good over 20-25 lb when you by it but im bighting my tongue , i can get through this, im persistant , maybe i just need some cheers and some R&D cash !
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
2001 E350 4.10 all stock cargo 140k
VISIONQUEST is offline   Reply With Quote
