Originally Posted by getrolfed
I recently did my own clutch linkage repair and documented it to share. Rather than using the stock nylon bushing, I modified a 5/8" female rod end heim joint. Its all very solid now and looks like it will last. Its also very servicable should it decide not to last!
Hope this helps someone
www.worldacumen.com/content/clutch.doc
Not to rain on your parade but there's a guy who's been selling a "kit" of sorts on Ebay using a cut down rod end like yours, but it's nice to have some intructions/pics too.
I did a similar mod several years ago and also eliminated the switch. More convenient and no close calls so far. Anyway IIRC I used a 3/8 rod end and didn't put a nut on the inside of the arm, just ran the both through both pieces, the rod lined up good this way. I also used a 3/8 bolt for the master rod - drilled a vertical hole in the head the same diameter as the rod, something like 3/16, and welded it, this provided adjustability too. I can take a pic if anyone is interested.
'94.5, rebuilt ZF5 S547 w/SB OFE, S&B AF, 3" DP & 4" Magnaflow exhaust, gutted EBPV, Beans fuel, 6.0L Intercooler w/Banks pipes, Bilstiens, Swamps IDM, Adrenaline HPOP w/later IPR, CCV Mod, A proud Texan 2WD XL!
