Diesel Forum - TheDieselStop.com - View Single Post - Help to decide upgrades on 2009 f350
Old 10-23-2009, 08:29 AM   #2 (permalink)
PowerstrokeConverters
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Congrats on the new diesel and on the first post, welcome!
power programmers that plugin can be programmed back to stock in a couple of minutes , so before taking it back to the dealer you should always put back to stock.
I believe K&N airfilters are the only ones that the company will back you up if the dealer gives you a hard time about having a non-stock filter, but you would have to use a drop-in type and not the entire system.
Tires and wheels, well check the web, so many out there, get a dieseltruck related magazine, subscriptions are dirt cheap nowadays.
Enjoy your truck, and make sure to create your signature, go to "my account" and on the left you will have the many options, including a picture avatar you can upload.
talk to you later
Adrian
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline   Reply With Quote
