Diesel Forum - TheDieselStop.com - View Single Post - Changing Fuel Filters
Old 10-23-2009, 10:33 AM   #3 (permalink)
senix
senix's Avatar
also oil the new o-rings don't put them in dry and don't use fuel. If the truck does not prime per the manual and as Captcaper did above try to press the fuel safety shut off switch and then crank.
A little trick I learned on mine. My switch is sensitive there fore I had to hold it down. Switch is located on passenger side of dash as you open the door.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now   Reply With Quote
