Just a swag....
As far as 10 lsb versus 15 lbs. If the system was originally designed to work without a cooler, then the cooler may be doing its job. In doing that though, air contracts as it cools, expands when it heats, etc. Kinda far fetched but not outof the realm of possiblity.
The other possibility is excess pressure drop trying to shove all that air hrough the cooler. Friction loss could possibly be playing a factor. Try to find some performance specs on the CAC.
Griffy71
Necessity is the mother of invention.
If it jams, force it. If it breaks it needed fixing anyway.
01 F-250 PSD 4x4 Extended Cab, Bully Dog Chip, Homemade Tymar, AIH delete, Fumoto Drain Valve, Wicked Wheel.
