Cary will probably explain this better, but the whole point of the RSK with SD springs VS a lift kit is that the springs are longer and the shackles are moved to the rear where they work with the spring travel rather than against it. Stock SD springs have a lot of engineering or the taper leaves and spring rate to get the best ride possible out of a leaf spring. The only other spring coming close is IKON lift springs because of the multiple thin leaves.
Don't mean to be rude but if you think a lift kit is the same thing you are missing the whole point of designing a suspension to work insted or reaching a height for the lowest price. Big difference. The RSK / SD swap makes a working suspension.
Diesel Mechanic 28 yrs
