Have it checked for codes. Most likely you have a high pressure oil leak. D-rings on oil rail plugs and stc fitting are most common. Swapping modules with the X won't do any good, as the pcm's have completely different strategies, as the 03 will have the "inferred ebp programming". Your X probably has PATS that will not allow engine to crank, if it is so equipped.
