Diesel Forum - TheDieselStop.com - View Single Post - DIY Clutch Linkage Repair Instructions - heim joint, bushings
Old 10-24-2009, 12:51 AM   #3 (permalink)
Garbage_Mechanic
I did something similar to this and used an industrial "micro" switch with whisker on it for a neutral safety switch. The original switch is also a redudant cut off for the cruise control so I added a second push button style micro switch for that. Been perfect for about 3 years!
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline   Reply With Quote
