Diesel Forum - TheDieselStop.com - View Single Post - Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Old 10-24-2009, 03:23 PM   #46 (permalink)
Ears93
Ears93's Avatar
You guys are lucky. I'm still trying to get my tach freq. Figured out. The 94-97 has a higher freq. Than the 98-02 7.3. I have reead about a couple things to do, but not very detailed though. I too have the ABS light on when the bulb is in along with a problem with seatbelt light and water in fuel light. I have read that you have to remove a transistor or a resistor on the ABS light and switch the polarity on the water in fuel and seat belt light on mine but I haven't seen anything really detailed about it. Other than that everything else works great.
Nick
97 E350
Extended Cargo
7.3 Stroker
230,000 Miles
Muffler and Cat Delete
Rebuilt trans with updated parts
More to come but I won't bore you with that crap till its done.
Ears93 is offline   Reply With Quote
