Originally Posted by BFrank
I have a similar problem, however different. My computer is confused and thinks when my passanger door is open when it is closed and closed when it is open (backwards). therefore, the light is on when the door is closed and off when open, as well as the dash indicator.
Confusing, any suggestions would be greatly appreciated. Driving me crazy...
Ford F250 7.0 Lariet 6 speed manual
Same here. For quite a bit of time the passenger door would always show as closed even when open. Annoying but livable. Now it is backwards also. Door open, truck thinks closed. Door closed, truck thinks open. If I close it part way, first click, truck thinks closed. When I close it all the way, two clicks, dome light on. All my other VSD functions are doing fine. I replaced the door switch (not latch) today but it did not help.
This is a '03 F250 Crew Cab. Could it be the actual latch is malfunctioning inside? I have tried the WD-40/lube bath but it did not help.
